using old 305 injectors on new 350 block with 305 heads
Old Sep 9, 2004 | 09:38 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i have a brand new 350 block, bored 30 over with a hydrolic flat tappet cam, with about 420 intake and 444 exhaust lift. it is a mild 350, and i am using the same 305 heads, however they have better springs, and they are newly machined. i am going to be using the exact same TPI setup, only i am changing the knock sensor to a 350 knock sensor. will this all work? if not, what do i have to change? thanks!
Old Sep 11, 2004 | 08:40 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
HEY THERE, i also have a 355 with 305 heads but i have 350 inj's.iv'eread you can run 305 inj's but you need a adjustable fuel pressure regulator, and iv'e been told that the 305 heads put a damper on the horesepower like 30hp..so i'm looking into a set of 350 heads myself. DON'T get me wrong my cars pulls like a bat out of hell and i like it.. iv'e had my combo running for about 5 yrs...good luck and enjoy the R U S H...
Old Sep 11, 2004 | 09:30 PM
bigchief's Avatar
thanks for the info, im just a little confused... you say i need a fuel pressure regulator, what happens if i start up the car without that?.... thankss
Old Sep 11, 2004 | 11:16 PM
88fbird's Avatar
Car: 84 S-10:(
I don't think it is going to hurt anything to run the stock fpr. You might want to keep your eyes open for an adjustable one though. But not a show stopper.
Old Sep 12, 2004 | 07:25 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I think that's because he's using the 350 injectors instead of the 305's, I'd get one because any time you modify an engines ability to breath you're going to need tuning and that includes fuel pressure.
Old Sep 12, 2004 | 10:11 AM
88fbird's Avatar
Car: 84 S-10:(
I think he is saying the 305 injectors will work with a higher fuel pressure. The only way to up the fuel pressure is with an afpr. I think it isn't that big of a deal. It should run with the stock regulator until he can get an adjustable one. That is an easy swap that can be done a little farther down the road. It might not be the perfect set up, but if you just want to get it running, it should do.
FBird
Old Sep 12, 2004 | 05:25 PM
bigchief's Avatar
alright then cool... i just want the thing running for now, in a month or so i'll upgrade the injectors and the chip in the car. thanks for the info guys, ill let you all know how the start up goes
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
