SuperCharged TPI ?'s
Old Sep 9, 2004 | 01:54 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Does anyone know where to get a paxton supercharger for a 87 Iroc wit TPI. Also what is the power limit when building an engine using the stock 350 TPI engine block. Is TPI ok for a supercharged 383 stroker TPI engine..
Old Sep 9, 2004 | 02:03 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
year one has them for around 3 grand for a complete kit
Old Sep 9, 2004 | 06:33 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I would be willing to bet that kit is for 88-92. You'd need to do a full serpentine swap on that '87 to make use of it.
Old Sep 9, 2004 | 09:43 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
Forget about Paxton. I would suggest getting either a Vortech super charger kit or a Procharger kit. The Procharger is what I would reccomend since it comes with an intercooler. My brother had P1SC model on his 95 T/A and it s a good kit.
Old Sep 9, 2004 | 09:57 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
look at my times 12.71 at 111mph on street tires stock tpi intake and prom old paxtons are still good do not need intercooler have alky spraying in.my times are better than some ati and vortech guys.
Old Sep 9, 2004 | 10:02 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
They are not as reliable and have limitations compared to the Procharger or Vortechs. The old ball bearing design it way outdated.
Old Sep 10, 2004 | 06:48 PM
antoine's Avatar
you are right but some paxtons last a long time if you have the cooler and change atf and not overspin it
Old Sep 10, 2004 | 09:34 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I'm not saying Paxtons are junk they work well. You can get good performance out of the Paxtons, your a good example. But if your gonna spend the money why not get something better that will last in the long haul.
Old Sep 11, 2004 | 04:56 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
I have a paxton on my 85 got it when I bought it...fuggin fast.
if i had to buy another one i would go with vortech, paxton ball drives are outdated....
Old Sep 11, 2004 | 09:52 PM
Toneyb35's Avatar
Car: 91' Z28 Vert
Engine: 305TPI
Transmission: 5 speed
You're the guy I've been looking for. I have a 91' 305TPI that runs very well that I want to supercharge until its time to replace with a 350. So you say ProCharger would be your suggestion for the best application for my vehicle???
Old Sep 14, 2004 | 08:28 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I think the Procharger would be the best choice.
Old Sep 16, 2004 | 08:29 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Kind of related:
A friend of mine was saying that the procharger was harder on the engine than any other systems. He said that since it made more boost, it was harder on the engine while street driving.
Old Sep 16, 2004 | 09:18 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Originally posted by Maroon-IROC-Z
Kind of related:
That's what boost controllers are for. If you're going to SC do it right.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
Sanjay
Aug 12, 2015 03:41 PM
