re: Fuel line's LT1
Old Sep 9, 2004 | 03:23 PM
donfox1's Avatar
Car: 1991 Camaro RS
Engine: 1994 LT1
re: Fuel line's LT1
Getting close to finishing up Project Car. 91 Camaro RS which had a 3.1. Put a LT1 out of a 94 Caprice. (Don't have Donor Car) Is their an After Market Vendor that I can get the correct Connections from? Problem is Stock Rubber Gas Line's from Steel Lines, to Aircraft Connections on Engine. The Rubber Lines have Threaded with O-Ring Seal. Line's comming out of engine have been cut and are the Factory heat sweated connections to Aircraft Connectors. How can I put the two together? javascript:smilie('')
Old Sep 10, 2004 | 02:55 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I make custom LT1 swap fuel lines. I don't understant fully what you mean by "Factory heat sweated connections to Aircraft Connectors". I am assuming you mean AN fittings on the LT1 fuel rail?
E-mail me at john@lt1intake.com and enclose pictures if you can.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
