check engine light FLASHES at WOT wtf?
Old Sep 8, 2004 | 10:12 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
ok my trans am's check engine light flashes at WOT above like 4grand only... and doesnt through any codes... already pulled the maf to see what the deal was but thats not it... replaced the ignition module thinkin it was bad but same problem.... the fuel pressure does blead off when i try to start it but dontknow if that was adding to the problem
Old Sep 8, 2004 | 10:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Is the engine missing when the SES is flashing?
Old Sep 8, 2004 | 10:38 PM
86IROCTHD's Avatar
Car: 88 Trans Am
yea well it kinda seems like its cuttin out... is surges and surges untill the rpms are kicked back down under like 4 k ie shifting into the next gear....
Old Sep 9, 2004 | 10:19 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmn, if the SES is flashing during the miss, then I'd suspect you're losing ignition pulses...since you changed the ICM already, I'd suggest a look at the PU Coil for corrosion at the connector and the PU coil itself.
Old Sep 9, 2004 | 08:16 PM
86IROCTHD's Avatar
Car: 88 Trans Am
funny u said that when i changed the module i notice that the connector had be broken apart either from heat fatiqe or something of the sort should i remove them and heat shrink it?so i do not get a arc?or replace the pick up assembly?
Old Sep 10, 2004 | 10:26 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd replace it. Cost is about $10.00.
You need to remove the dizzy, knock the roll pin out of the drive gear, take the gear off and slide the shaft out to get the PU coil out.
Old Sep 10, 2004 | 10:42 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Umm... how about pulling any codes as well.
Old Sep 10, 2004 | 11:07 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: check engine light FLASHES at WOT wtf?
Old Sep 10, 2004 | 11:13 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Bad Devil!!
Old Sep 10, 2004 | 05:53 PM
86IROCTHD's Avatar
Car: 88 Trans Am
thanks peeps i will try the new pu coil
Old Sep 10, 2004 | 09:23 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
The best way to fix a pesky engine light.....black tape!
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
