Holley AFPRs
Old Sep 6, 2004 | 10:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Holley AFPRs
I was recently able to track a rich condition down to my Holley AFPR. It seems that it does not drop pressure at all when there is little to no vaccum. It stays at constant pressure. But before we say the AFPR is bad I will say that I see manifold idle vaccum in the low 50s as I have an LT4 "hot" cam. So needless to say I have less vaccum than stock cars.
I am able to start the car, rev the engine, disconnect the vacum line and repeat with the line disconnected and not have varying fuel pressure. I do get varying MAP readings from 30-100 so I am deffinatly seeing fluctuating MAP for the AFPR to dhange. Also the line is not bent or anything. The pump can handle the fuel pressure as it is a new walbro and does not drop pressure at higher pressures at WOT.
I guess what I am wondering is is my AFPR diaphram bad or is this expected. I have heard about Holley AFPRs having trouble in the past.
Old Sep 6, 2004 | 11:22 PM
bobsroc's Avatar
Car: 1987 IROCZ
If the vacuum doesn't change fuel pressure, decrease it, then I would say AFPR isn't working as well.
Old Sep 7, 2004 | 11:28 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
My holley AFPR that comes with the HSR doesn't have a vacuum port IIRC...
Old Sep 7, 2004 | 11:34 AM
bobsroc's Avatar
Car: 1987 IROCZ
Interresting, how does it regulate fuel pressure then? At idle you need less fuel/pressure, as engine vacuum decreases with acceleration you need more fuel/pressure. What is going to control that if your vacuum isn't?
Old Sep 7, 2004 | 12:01 PM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
TBI FPR's don't have vacuum control either. Although in the TBI you might have 12-13psi vs 43 with the TPI.
Old Sep 7, 2004 | 01:43 PM
Tibo's Avatar
Car: 1991 Z28 Vert
It has the vaccuum port inside the screw(down the middle of it) that is where a vac. line hooks up. If not, it is not an AFPR.
Old Sep 7, 2004 | 02:43 PM
bobsroc's Avatar
Car: 1987 IROCZ
Tibo quote:
Thanks for clearing that up Tibo, I was thinking they came out with a MAFPR (magic automatic fuel pressure regulator) or something when I wasn't lookin.
Old Sep 7, 2004 | 10:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Shrugging aside Bobsroc's last comment; I did some research of the Holley AFPRs and found that many times the wrong AFPR was sent out. Mine displays the same symptoms as others (10psi drop when turning the screw, not much idle/WOT difference).
Old Sep 7, 2004 | 10:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Forgot to add that I found it out at http://www.stealthram.com (not to promote another website or anything.)
Old Sep 9, 2004 | 02:37 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally posted by bobsroc
Tibo quote:
Sh*tty...So where am I supposed to hook that up now? Just any vacuum port off the manifold?
And is tightening that screw or loosening it raising FP?
Old Sep 10, 2004 | 10:46 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
bttt...? where's the vacuum line supposed to hook up to?
Old Sep 10, 2004 | 10:55 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Normally it's hooked up to the plenum (not the throttle body)
Old Sep 10, 2004 | 06:29 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Would it be okay if I T'd into the MAP sensor line?
Old Sep 10, 2004 | 10:17 PM
vernw's Avatar
Should be okay there.
RedLeader289
May 28, 2019 01:47 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
