test drive w/ scanner readings
Old Sep 11, 2004 | 12:20 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Just went for a test drive, first drive in two years. Here's what the scanner was reading after I got back and parked it.
coolant temp = 177.3 degrees
start up temp = 78.8 degrees
TPS = .62v
rpm = 692
O2 sensor = 4mV-
O2 cross counts = 84
block learn = 160
blk lrn cell = 0
integrator = 129
IAC = 6 steps
desired idle = 700rpm
engine load = 31
manifold temp = 132.8degrees
EGR cycle = 0%
CCP cycle = 0%
battery voltage = 13.5V
fuel pump = 12.8V
spark advance = 15.7 degrees
knock sensor = 138
knock retard = 0 degrees
injector pulse = 1.4mS
run time = 1268 seconds (21 minutes)
map sensor = 2.78V
MAF = 4gr/sec (unplugged, MAF is bad)
lean flag
closed loop
Just gotta go start working on adjusting those rockers so the ticking will go away. There's also an air leak on the upper intake, and I've got new gaskets for it.
Think I can have it completed in 2.5 hours?:lala:
Hotrodboba400
Dec 10, 2019 07:07 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
lanceflame44
Sep 25, 2015 12:28 PM
