My new motor!!
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
My new motor!!
Time to ditch the LB9. It's been good, but time for some 11's
Here's what I picked up
355 L98 2bolt block, Eagle crank/rods, Lunati forged pistons, AFR 195's, stainless 2.02/1.6, ProMag 1.6, LPE 219 cam, Ported Super Ram base, runners, plenum, BBK 58mm TB, MSD distributor/coil.
Customer of mine gave me a deal I couldn't refuse. Let's just say I paid less for the whole motor than I could have found a SR setup for
All new with 1000 miles on it. Only problem is that it was setup for a blower so I have to re-ring the thing since they're gapped loosely. But it's worth it.
I just ordered the Dyno for the shop, so that ought to be in the ground about the same time.....I'm anxios to see what it makes.
Here's what I picked up355 L98 2bolt block, Eagle crank/rods, Lunati forged pistons, AFR 195's, stainless 2.02/1.6, ProMag 1.6, LPE 219 cam, Ported Super Ram base, runners, plenum, BBK 58mm TB, MSD distributor/coil.
All new with 1000 miles on it. Only problem is that it was setup for a blower so I have to re-ring the thing since they're gapped loosely. But it's worth it. I just ordered the Dyno for the shop, so that ought to be in the ground about the same time.....I'm anxios to see what it makes.
:hail:
