++What do you think?++
Hey, sup guy's!! First time on the board
Well I just want to run my setup buy the pro's here and see what you guy's think of my setup
this is going into a 87 s-10 blazer
87 TPI setup
old style 350 block .40 over to a 357
Speed Pro Hyper. 125 dome pistons
Sportsman II heads 76cc should be around 10:1ish comp. ratio
Cam is Comp #12-262-4 Dur is I:218 E:224 Lift I:464 E:470
Painless Harness
Going to get a BBK 54mm T-Body (what u think of these?)
have 24 lb/hr injectors and adjustable FP regulator
700r4 Trans will be fully rebuilt with corvette parts
NEED stall converter what size u think?
going to get a custom prom (from where?)
What will I be looking at for HP and Torque and maybe 1/4 times
dose this look like a pretty good setup? ANY feedback is appreaciated thanks to all who help me out
87 TPI setup
Painless Harness
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Suggestions:
Edelbrock base manifold,
Larger runners of choice,
If you're on a budget leave the TB for later, otherwise the BBK is fine IMO, but won't give too much hp.
Headers of choice,
2600 RPM stall speed converter of choice (it's not a "stall converter", it's a torque converter with a stall speed of XXXX RPM, even a stock converter has a stall speed - around 1400-1800 RPM - maybe you know this, but it's good to repeat this as often as possible).
TransGo shift kit from http://www.700r4l60e.com/ which is the pro-built site I guess, since it used to be pro-built.net and I got forwarded there.
I'm assuming you are using the 87 MAF style TPI, I'd switch to the $6E bin mask and eliminate the cold start injector - go to the DIY board for learning about that (I started with AUJM (iron heads, more conservative timing than ARAP), but I've tweaked it to be in between the two, and turned the fans on at a cooler temp, turned EGR off, leaned out the power enrichment some (stock is so rich at WOT), etc...). Also, with anything away from stock you are throwing money away with mail order chips - buy a Moates' Autoprom and do it yourself http://www.moates.net/.
Power - should be good
Torque - should be great
quarter - should be much better than stock
You're welcome
Headers of choice,
You're welcome
THanks very much man. I am a Technician so I am good with car's (new stuff at least) Will I do o k with my stock intake? I don't have the money to get a new one yet and want to save up to get a mini ram or somehting like that. also planning on 100 shot just for fun. I am using headers as well. are those autoprogramers good that you are talking about? Easy to use? What u think my 1/4 mile times would be around in a s10 blazer? 13's? with out the nos?
Thanks very much any other suggestions or comments appreaciated thanks!!!
Car: 87' IROC
These cars don't use the autoprogrammers, those are OBDII cars ours are OBDI. You have to take the prom (chip) out of the car burn it on your computer and reinstall it. The stock TPI stuff will really hurt but it will still run ok. It would be WELL into the 13s with a thirdgen, i'm not that familiar with s-10 suspension and such but with good tires i would guess you should be in the 13's.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I think he was referring to the AutoProm or Prominator. Haven't got one yet but am hoping to sometime in the future (realtime tuning rocks
) I know it will hurt me but I don't have the $$$ for new intake stuff now. How hard are they to burn new prom's and how do I know what to burn it to? S10's are lighter I think than a 3rd gen. I will also have air bags and a 3 or a 4 link in the rear. I think I might just get my t-body board out by this compony on the net. Anything else?
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Daniel
I will forsure check into that!! DO you guy's think i will still be ok with my stock intake or what? I know it isn't the greatest but will I run ok? I've been thinking of getting my t-body rebuilt what do you guy's think of that? Guna run some 3.73's in the rear also. I should have this thing up and running in the next 2 maybe 3 months. It's been over a year now LoL!!
The intake would work for now, but when you can get a different one, I would do it. It's going to be choking pretty quickly with 3.73 gears, it might be better to port our your stock plenum, runners, and manifold to just get a little more air until you can afford the new stuf.
Ya, I did do some porting on my runners and plenum (mainly Plenum) What do you guy's think a good rear gear would be? This thing doesn't need to be insane because it is a s10 blazer and it's very small and light. Just want a good street ride to cruze around in! Love your guyes input and help it's greatly appreaciated!!
Depends on how much power you think you will be putting to the wheels, or if you will be using slicks, or street slicks.
In that case, I would just stick with the stock rear until she goes, which if you keep the oil clean and changed on time, it will last a while. This is, of course, only if the rear isn't an open diff. If it is, toss it.
I am sure it is a open. I "think" that it is a 7 1/2 or is it a 7 5/8? Anyhow, i have a 95 with a 4.3 5 speed and it as a sweet *** 8.5 rear maybe I could switch them LoL! Oh and I work in a shop so I keep ALL my maitance up to date on EVERYTHING that is very important to the life of a item i think!
If it is an open, I would just try to find a good deal on a posi/limited slip system. You will lose a lot of time if you can't get off the line.
Good luck, sounds like it'll run.
