AIR pump outlet tube and emissions
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Three fairly short topics/questions:
1. I noticed my AIR outlet tube is actually kinked where the two bends are on its way to the diverter valve. Pretty severely, actually. Not enough to completely close off the flow, but definitely enough to significantly reduce the flow. Has anyone else seen this? I suspect this could be part of the problem I failed the emissions sniffer with high CO values (of course my HC were high too <sigh> )
2. I've seen several posts about the diverter valve going bad or being "stuck". How do you test or determine if the diverter valve is okay or not? What about the check valves?
3. I saw someone mentioned that the diverter valve only flow air into the exhause pipes during open loop, and during closed loop everything goes to the cats. Can anyone confirm this for me?
Have a Great Day!!!
- Vern
Have a Great Day!!!
- Vern
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i can't confirm the airflow, but can confirm the tube being kinked. i thought the same about mine, bought a new one, and it's made the same way...
KAM
KAM
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I know when I put the ECM in diagnostic mode I hear one of the solenoids click. (A->B)
I never confirmed which of the two AIR control solenoids it was though.
1992 Trans Am
May 10, 2023 07:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
Street Lethal
Aug 12, 2015 11:33 AM
