90-92 Plenum pics needed!!!
Old Sep 20, 2004 | 06:51 PM
92GTA's Avatar
When I removed my plenum I also removed all of the little vacuum hose nipples and now I've lost track of which went where
Can someone post pics the plenum so I can see which screw into where. Hopefully pics without lines attached so I can see the diameter of each hookup...
Thanks!
Old Sep 20, 2004 | 10:47 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Hope this helps... The two little ones are the same size, the only other one is the power brake one in the driver's rear corner of the plenum.
Old Sep 20, 2004 | 10:51 PM
92GTA's Avatar
Perfect, thank you!!!
IROCZ1989
Jan 24, 2016 03:55 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
