Help me find fuel rails!
Subscribe
Sep 23, 2004 | 04:10 PM
i've called everyone trying to track down a used set of tpi fuel rails with no luck. not a single yard within 500 miles of my area has a tpi motor and many of the used tpi online parts places don't have rails.
can someone please help me find a set of rails!
Reply 0
Sep 23, 2004 | 04:17 PM
Post the area that you are in and one of the board members can possibly point you in the right direction. Also what year car are you looking to put them in?
P.S. Could you also kindly remove the text mssage that you have in your sig block,
Reply 0
Sep 23, 2004 | 04:18 PM
a 92...does it matter what year it is as long as its tpi? i was told vette rails would work as well. would they?
Reply 0
Sep 23, 2004 | 04:22 PM
Yes it matters because the rails up until 1989 had a fitting at the rear of the left rail for a cold start injector. If the vette rails are for a LB9 or L98 then you shouldn't have any problems with them.
Reply 0
Sep 23, 2004 | 04:26 PM
ok i'm looking for rails for an 89 and up l98 style plenum and runners with a scdp fastburn/vortec base.
Reply 0
Sep 24, 2004 | 06:56 AM
You can easily put a cap on the 9th Injector bung if thats the only set of rails you can find.
been there done that when I sold off ally my stock SD efi stuff. They desided to go back to efi and picked up some rails with the cold start and just caped it off. never had any problems.
Reply 0
Subscribe
