Name Those Sensors!!!
Old Sep 24, 2004 | 10:23 PM
92GTA's Avatar
In the last 12 months I tried to replace every sensor, solenoid, and valve I could thinkg of. List all of the ones you can think of so I can see if I missed any. Here are some of the ones I can think of off hand:
o2
MAP
TPS
IAC
EGR
Ignition Module
Pickup Coil
Knock Sensor
Charcoal Canister Solenoid
Old Sep 24, 2004 | 10:58 PM
87Formula4bbl's Avatar
Car: '87 Formula
MAT ?
Old Sep 24, 2004 | 11:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Coolant temperature Sensor, Coolant temperature Sending unit, Fuel Pump/Oil pressure switch sending unit, Fan Switch, EGR temperature Diagnostic Switch.
Old Sep 24, 2004 | 11:14 PM
92GTA's Avatar
Yup got the:
MAT
Coolant Temp
Fuel Pump/Oil pressure switch sending unit (Looking for an 80psi V6 one though)
I didn't even catch the:
Fan Switch (For the secondary right?)
EGR temperature Diagnostic Switch (whatever tht is )
Old Sep 24, 2004 | 11:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes the fan switch would be for the secondary one if you had a dual fan system and for the primary one if you didn't. Don't worry about the EGR Temperature Diagnostic switch since it doesn't apply to your car. It's late when I typed that in.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
