Change MAF to Speed Density
Old Sep 25, 2004 | 05:10 AM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Ive recently sold my 1985 305 TPI/700R4 combo to my mate to go in his 34 Ford HotRod.I thought it would be easy to buy a Painless Wiring Kit to fit this but they tell me that it fits all except for the 85 Model TPI!!!
So i thought i could go for Holley Commander 950 like ive got in my TA now,but holley tells me it will not work with MAF and i would need to convert to Speed Density.
Whats involved in doing this??
cheers
pM
Old Sep 26, 2004 | 01:45 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I'm sure doing a search would help you. You will need an ECM from a 90-92 Camaro. Number 7730 and a speed density wiring harness (Painless 90-92, get the longer harness) or make your own. You will aslo need to make sure you have the right memcal with the ECM. You'll need to get a map sensor as well. You will have to change your knock sensor to a model 92 camaro 5.7 liter one. It uses a different ohms setup than the 85 one. The harness will fit the HSR setup. Thats for starters. If I forgot something, someone else can add to it. Been awhile since I did it.
Old Sep 26, 2004 | 03:30 AM
powermite's Avatar
Car: Transam
Thanks for that Capt.but i was thinking of using the Holley ECU with their wiring harness.
Am I correct in assuming that the commander 950 does not use a knock sensor?I cant remember having one on the new system in my TA
PM
Old Sep 26, 2004 | 07:53 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Upgrading to SD for a Holley 950 is a matter of Removing the MAF sensor adding a MAP sensor. I think the MAP sensor, 02sensor and MAT sensor come with the holley 950. Go here this will help out a little https://www.thirdgen.org/techbb2/sho...=commander+950
Steve78LT
Feb 24, 2016 12:15 AM
Keith5
Aug 27, 2015 04:37 PM
nuggie
Aug 25, 2015 01:27 PM
perZ
Aug 15, 2015 01:17 PM
86Base
Aug 8, 2015 01:34 PM
