car backfiring through intake
Old Sep 26, 2004 | 12:47 PM
91 z28 350's Avatar
Car: 91 Z28
My car started to stumble at WOT so i figured i needed a new fuel filter so i changed that it helped a little but it still would miss sometimes when i hammered on it. So i changed the spark plugs,wires,cap, and rotor and ran even worse when in gear, so i checked for cracked plugs made sure all the boots were on good (its hard to get the msd boots on with slp headers). So i try to start it after all that then it is hard 2 start then it backfires through the intake and i didn't . What could be causing this i know my vavle seals are worn (smoking on cold start ) could that be causing a intake valve to stay open ?
Old Sep 26, 2004 | 06:20 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
sounds like its out of time man.. that would be what i check first thing
Old Sep 26, 2004 | 06:57 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I agree. Sounds like timing. Check fuel second. Lean pops "up"Rich pops out the exhaust.
Old Sep 27, 2004 | 01:42 AM
87tpi's Avatar
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Are your plug wires in the right firing order?
Old Sep 27, 2004 | 11:19 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
I had the same problem along time ago on a high milage 350. it turned out to be a worn exhaust lobe on the cam. It wasn't opening the exhaust valve fully, and at WOT it would pop out the carb.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
bryan623
Aug 10, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 12:07 PM
