this is what i got how do imakeit better
Old Oct 2, 2004 | 06:57 PM
grndprixss's Avatar
Car: 85 pontiac grand prix
Engine: 355 tpi
i have a 30over 350 witha balenced and blue printed bottom, about 10.4 compression chevy bow tie phase 3 hads midly ported 220/230 520 lift 114 lsa with a stock tpi intake set up with 24# injectors and a chip programed by fastchip, how much do you think this combo will make and how can i make it better im looking at a few intakes and wonder what would be best
Old Oct 3, 2004 | 12:28 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Before going into a detailed post I would like to know if you have read all of the tech article and stickies? They are bursting with free to semi free modifications and lots of product knowledge.
Old Oct 3, 2004 | 12:32 PM
grndprixss's Avatar
Engine: 355 tpi
i have read a few of them my whole thing is my intake that seems to be my weak point i wanna work on that but i love the tpi runner look and i know it plain and simply sucks on a modified motor
Old Oct 3, 2004 | 12:40 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There's several intakes..Holley Stealth Ram, Accel Super Ram, TPIS Mini Ram, etc, etc, you need to determine a coulple of things...cost as well as if you need to keep it emissions legal for your area. There's also many differnt combinations of runners and bases (Edelbrock, AS&M, Accel to name a few)
Forget the looks of the GM TPI intake, you'll probably be able to free up a good 50-60HP with a good intake that will take advantage of your heads and cam setup.
BTW,
Welcome to thirdgen.org!!
Old Oct 3, 2004 | 12:44 PM
grndprixss's Avatar
Engine: 355 tpi
every company makes claims to how much hp their product can make but really what are the gains the stealth ram looks the best and closest to the tpi and with my tig welder i can make it look the same but really how much will it make
Old Oct 3, 2004 | 03:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Forget about the claims, and go with the guys who have BTDT.
www.stealthram.com has many dyno posts.
The Super Ram has propelled many a 350 into the low 12's with mild cam/CR setups...albeit with good heads., the MiniRam has/was/still is???? the King....the LT1 intake conversion has shown good results as well,...as mentioned before, do a search and see what fit's your needs, or what others are doing with the combo's.
Old Oct 3, 2004 | 03:39 PM
grndprixss's Avatar
Engine: 355 tpi
thanks for the link it seems likei have a good idea on whats next but i see everything for mid tq and hp but whats up with the low end, my car was built for more street than strip, and another question what is every one running as far as mpg goes i am running about 11 and it seems low
Old Oct 4, 2004 | 11:28 AM
Tibo's Avatar
Car: 1991 Z28 Vert
HSR is a good way to go. Wtih the right gears and cam you will not notice a loss in low end. It will also allow you to give it more throttle on the launches with out as much tire spin. I love my HSR. It is very good on the street. And you wont truely know what others mean by the 45-6500 RPM pull untill you experience it yourself. What fun.
Old Oct 4, 2004 | 06:27 PM
grndprixss's Avatar
Engine: 355 tpi
tibo you seem pretty good with this set up and we seem to have a similar engine, my question is how will the hsr benifit me in the 15-3000 range since that is where most of my driveing and i have 3.42 gears with a 220/230 520 lift 114 lsa cam
Old Oct 5, 2004 | 01:31 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Believe it or not, more the latter, I still (LOL) have my stock 2.73 open differential. I am putting in the 3.45 posi disc rear end on Monday. SO, I used to have a 305 TBI with WP Torquer SRs and some other stuff. The new setup with a higher cam still comes out of the hole better because I can give it more throttle. So with 3.45s it should be a whole new ball game. It really is not bad in the 1500-3,000 RPM range with my low gears.
I have a 5 speed and had to work on the in town take off, but yeah, it is still good. I have a good tune though. Did that make sense?
Old Oct 5, 2004 | 03:00 PM
grndprixss's Avatar
Engine: 355 tpi
kind made sensei think
