MSD Fuel Pumps
Old Oct 4, 2004 | 04:18 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
MSD Fuel Pumps
Has anyone tried putting an MSD high pressure fuel pump under the hood rather than close to the gas tank, as they suggest.
I want to put it under the hood to keep it away from the snow and ice, but I am not sure if it will work properly if I do this.:hail:
Old Oct 5, 2004 | 10:59 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
With the deminishing real estate under the hood, it's difficult to keep a fuel pump from vapor-locking in hot weather, but if heat isn't a problem (you mentioned snow & ice) then yes, you can put it in the engine bay (where? it needs to be at or below the level it was in the gas tank.) Fuel pump are in the gas tank to keep them cool to eliminate vapor-locking, and reduce the noise high volume pumps produce.
Old Oct 6, 2004 | 10:14 AM
wrightz28's Avatar
Car: '88 GTA,'85 z28
Engine: L98, LB9
Transmission: 700 r4
Axle/Gears: sleepy 3.23, hello 3.73
A problem I could see is the elec. pump is a pusher, not puller like the good 'ol mechanical pumps. I would think you might have a pressure loss.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
