Let's say I wanted to replace...
Old Oct 5, 2004 | 11:46 PM
buymytransam's Avatar
Car: 2005 Audi A4 Avant
Engine: 1.8T
every sensor, relay and vacuum line on my 88 ISUK-Z with TPI. How much would that cost?
Old Oct 6, 2004 | 01:59 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Let's say I wanted to replace...
Why would you ask that question here? Not to be a jerk, but pick up the phone and call Checker Auto or your local parts store and ask them...:lala:
Old Oct 6, 2004 | 12:17 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
what capt picard said; try ur local auto parts but its going to be expensive
Old Oct 6, 2004 | 02:04 PM
Engine: 1.8T
Well, I'm asking because any time anyone ever has a problem with their TPI 3rd-gen they spend weeks trouble shooting, they replace every damn thing under the hood short of the engine itself only to find the problem mysteriously STOP with no explanation. Right now I'm having a problem with my shytbird Camaro, it stalls as soon as it starts. I've searched all over the boards and have not found an answer, only a bunch of suggestions that eventually amount to replacing just about everything that can be unbolted or unscrewed or disconnected. So I was wondering if anyone ever kept any receipts.
Old Oct 6, 2004 | 03:10 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Have you:
1. Checked fuel pressure.
2. Do you have a scanner to check and see what your sensors are telling the ECM?
If it dies as soon as you let off the key, you have an electrical problem somewhere. Simply replacing every sensor/relay under the hood may or may not help you.
Find the problem, and fix the problem. Don't spend a bunch of money you don't have to. (for that matter, for the price of all the sensors/relays, you could take it to a shop and have THEM fix if for less.....)
Old Oct 6, 2004 | 07:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
So every time you have a problem with the way the engine runs, you're going to drop 7 bills on sensors, etc?
Think I'd invest in a scantool and manual
gta90
Sep 15, 2015 04:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
E Rod
Aug 28, 2015 05:17 AM
Logan Bryant
Aug 27, 2015 11:52 AM
86White_T/A305
Aug 17, 2015 12:16 AM
