TPI mechanical temperature gage
Old Oct 7, 2004 | 04:31 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
I really want to use a mechanical temperature gage on my motor. I can’t seem to fine a left over hole anywhere. There seems to be a sensor in every hole. The gage I am trying to use is an Autometer mechanical.
If anyone has used a mechanical type temperature gage could you please tell me where you plumbed in the sensor?
Old Oct 7, 2004 | 05:29 PM
SloNlo350's Avatar
Car: 2005 GTO
Engine: LS2
Since my motor is newer I don't know if this is the same, but the water temp sender in the driver side head only sends to the gauge so I'd imagine you can put it there. Again, since my motor and all the stuff not related to the TPI is from '95 it might not be the same, but its worth a shot.
Old Oct 7, 2004 | 06:17 PM
87350IROC's Avatar
Car: 87' IROC
Yea the sensor on the drivers side head between the 1st and 3rd exhaust primary is the one for the stock temp gauge. So you can remove that and put your new one in there.
Old Oct 7, 2004 | 07:58 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Thanks for the information, I will try and find that spot first thing in the morning. It must be hiding just below the exost manifold.
Old Oct 7, 2004 | 10:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You could use the coolant drain plug above the oil pan seal on the drivers side (the one on the passenger side has the knock sensor in it). It's 3/8" NPT..
Old Oct 8, 2004 | 05:52 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
IT LIVES!!
I found the sweet spot between 1 & 3.
Thanks to the people that answered my dozen posts this week my TPI motor started today for the fist time in its new shell, it lives! Today was a good day.
Thanks for the help!!!
gta90
Sep 15, 2015 04:00 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
g.l.mos
Aug 22, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
Irocohio
Aug 12, 2015 08:03 AM
