Tpi 355
Old Oct 9, 2004 | 12:08 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Tpi 355
I think I may be buying a 355 shortblock and was wondering about sugestions for cam and heads. This is sort of a budget build so I would kind of like to stay under 1000 bucks when all is said and done. It is not a roller block btw. It will be going on my 85' and running 12s would be nice, but consistant low 13s would be acceptable.
Old Oct 13, 2004 | 08:29 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
12's and TPI ....with no power adder is a tough one The LTR design favors the bottom end ....while drag raceing seems to require RPMS to be better . Pick out your parts you want ..... find out what it all flows ....then call a cam company ....give them the numbers ...and they will usually hava grind in mind for ya
Old Oct 16, 2004 | 11:04 AM
brutalform's Avatar
too bad its not a roller block. is it going to be a tpi? if it is ,there are some nice cam profiles out there. converting to a roller will put your cost up. a cam with 212-228 @ .050 would work well in the engine. you can use an aluminum head if your cost permits, or get a 350 tpi steel head . with some porting and bowl work they will really perform well. my old engine was a 357, trick flow heads,(the old twisted wedge style) a zz-9 cam, and superram. i used edelbrock headers and a flowmaster cat-back, and 3.73 gears and a 5 sp. the car ran 12.90s all day long, with 1.68 ft., from drag radials. i know it can be done. it will cost a few more bucks than a grand though, unless you do your homework before you buy anything. alot of good used stuff out there. ..good luck, ...tom
Reddeath210
Oct 6, 2015 08:20 AM
JHX
Aug 29, 2015 02:30 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
