What is this? (pic)
Old Oct 9, 2004 | 08:10 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
What is this? (pic)
I was trying to check my fuel pressure the other day and I found this hose that is sucking air. I don't know if I knocked it loose or if it was like that before. Just wondering if anyone can give me some info on what it is, I have included a pic. Thanks in advance.
It is the black one infront of the cap.
Old Oct 9, 2004 | 08:35 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
that appears to be the line for the a/c. should be a hose to the left of it just hanging if that end is still on the plenum
Old Oct 11, 2004 | 03:09 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
That is the line that goes to the vent ducting in the car. There should be a hard platic line floating somewhere behind the head or distributor that attaches to that fitting. I broke the hard line on my car they other way when I was removing the air tubes at the back of the motor and now all I have is Defroster.
Old Oct 11, 2004 | 05:11 AM
camaro05's Avatar
Car: 91 Z28
I have had the same problem ever since I bought the car, (only the defroster works) Thanks for the info!
Old Oct 11, 2004 | 02:31 PM
camaro05's Avatar
Car: 91 Z28
thanks again guys, I just went out there and found where it plugs in. All the vents work now! :hail:
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
