LG4 to TPI - fuel pump selection
Old Oct 12, 2004 | 11:43 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
I'm looking at possibly using the MSD-2225. Anyone with any experience using this pump.
One concern I have is that it lists barb fittings for the fuel lines. Considering the fuel pressures for TPI are in the 40 psi range, is this adequate? Should I just use some braided hose and clamps to attach it to the metal fuel lines?
Lemme hear some thoughts as I'm hoping to start working the fuel system this weekend.
As always, thanks guys!
Old Oct 12, 2004 | 12:02 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have not used that MSD pump, I have a Walbro. However, I did use clamps for the first week I ran a MPFI set up. It was fine and never leaked. Make sure that the barb fittings go on really tight and you use two clamps for safty. You will be OK.
I ended up calling AeroQuip and talked them and got theexact fitings That I needed.
Old Oct 14, 2004 | 08:22 AM
DURTYBIRD's Avatar
Have a part # or link perhaps? I want to make sure I do this right since I'm really in no hurry.
I just ordered that pump, some fuel line and the blockoff plate for the mechanical fuel pump from summit so they are on the way.
Old Oct 14, 2004 | 05:11 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I used a holley 230lph inline pump mounted on the backside of the drv side rear seat.
Old Oct 14, 2004 | 05:31 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey Im swapping from 305 carb. to 350 TPI, and i wanted to see if u guys could tell me what the fuel lines from the fuel pump module are. I know 1. line is for the fuel feed, and the 2nd line is for the fuel return, the 3rd is for the evap and then there is one more and im not sure what thats for. Is it a feed and return to the evap canister? any response would be helpful, thanks
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
