zz4 cam, why so rich?
Old Oct 13, 2004 | 03:42 PM
2new2funny's Avatar
Title pretty much says it all!
The exhaust smell is awful- reminds me of the situation I had when I put in new (bigger) injectors and didn't modify the chip. Problem was solved once I chaned the constant.
The car is an'89 (mass air). The cam is basically mild but the lift is significantly higher than stock.
I don't know about drivability yet (tomorrow) so this could be the subject of another post.
**update**
I posted this on another forum and am getting some great feedback. Can anybody here help? I chose this cam because it was supposed to do well with the stock program, by all accounts!
Specs:
208/221 dur @ .050" lift
.474"/.510" lift
112 lobe sep.
Old Oct 13, 2004 | 03:56 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
How long did you let it run? What are your blm's?
Old Oct 13, 2004 | 06:50 PM
2new2funny's Avatar
It's run for about twenty minutes.
No BLM yet because I'm having a tough time with a laptop that has no seial port....
Old Oct 13, 2004 | 07:58 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I tooo have JUST started mine for the first time . With the 1989 stock 5 speed bin . the idle was dam steady .....a bit high maybe . I haven't hada schance to scan mine yet either . I will keep ya posted . But I have everrrrrrything new on it . In an attempt to not be chaseing down anything
I 'll post up later
once I get some values for it
Old Oct 13, 2004 | 09:45 PM
2new2funny's Avatar
IROC,
It looks like your set-up may be a little better breathing than mine and could possibly help.
I'm glad it's working out for you.
Which scanning software are you running?
Old Oct 14, 2004 | 12:31 AM
Abubaca's Avatar
I swapped in a ZZ4 cam this summer. I also added headers and exhaust, and had a valve job.
Everything else is bone stock. The car started right up, and ran so well, I didn't tune it for a day or two. I ended up timing it to about 10 degrees advanced. I don't know that it doesnt run just as good as with the stock cam, but it does sound a bit rougher...which is cool!
I'm gonna have it dyno tuned soon, but it runs GREAT now, I just want to pull all the power out of it that I can.
Old Oct 14, 2004 | 11:14 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Originally posted by 2new2funny
IROC,
nothing yet ....its still in the mail .....probably stuck at the border I havent really took the car out ....untill I see the A/F ratio .... I will post it up for ya if you want
Old Oct 14, 2004 | 03:46 PM
2new2funny's Avatar
Definitely, IROC, I'd appreciate the information and any updates!
Old Oct 14, 2004 | 03:49 PM
2new2funny's Avatar
I know what you mean about "rougher". My stock exhaust sounds lower and more "muscle carish". Funny how such a small change could affect it so much.
Continued success! Post the dyno results? When are you going?
Old Oct 17, 2004 | 12:07 PM
Abubaca's Avatar
hehe...well the newfound power blew the trans. I did have 170,000 miles so I can't complain. I just got the new one in, but it re-arranged my budget a bit !
....I'm hoping to have it dyno tuned by the end of the year, but I'm not holding my breath. I make a trip up north to see the family for turkey day and of course Christmas so that takes cash out of my "extra money" budget.
I'll make a new post when I get it done.
Old Oct 21, 2004 | 09:06 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Thinking of putting the ZZ4 in my '89. How did the swap go? Not looking forward to pulling it apart, but I've got new heads and valve train to put on anyhow, so I figured I'd throw a cam in to.
You guys did it with the engine in, right? (Took the radiators out, etc?)
Oh, and about the rich question - scan it and see where your trim is, then do some tuning. You'll probably have to pull some flow out of the MAF tables (1 and 2, I'd guess).
Old Oct 21, 2004 | 10:01 PM
2new2funny's Avatar
The swap went rather well, albeit a lot slower than I thought, mainly due to the fact that nearly EVERYTHING has to come out before you get to the little stick in the middle!
Mangus, when you say "pull some flow out" what exactly does this mean in newbie-speak?
I'm having trouble enough getting a cable that'll work made!
Old Oct 21, 2004 | 11:20 PM
Mangus's Avatar
Transmission: T5WC
Getting your tune right will likely require a chip re-burn, and the main modification will likely be to your MAF tables. Your MAF tables are respondible for controlling how much fuel gets delivered at a given airflow value. Its how fuel deliver is controlled on a MAF setup.
See the DIY-PROM forum for more info.
Jorlain
Oct 8, 2015 01:57 AM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
