TPI airbox
Old Oct 19, 2004 | 04:02 PM
custom88camaro's Avatar
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
TPI airbox
I was thinking on using factory TPI Airbox for cold air intake setup on my carbed engine. Does anybody know what the maximum flow is for the snorkel or box, whatever you want to call it? Anybody using this with built up TPI systems getting around 450 horses?
Old Oct 19, 2004 | 04:07 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The snorkel assembly isn't the flow restriction or the horsepower limiter of the TPI system... Yeah you could use it just fine (people have already).
Old Oct 19, 2004 | 04:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
if you do use the TPI intake system, make sure to gut the filter boxes so allow more air to flow up in there. Should be good to go with that.
Old Oct 20, 2004 | 02:07 AM
Car: 88 camaro
Engine: carby 350
Thanks guys. I can get the complete airbox from a 2.8 MPFI camaro for $20. Are the boxes/snorkels the same for v6 and v8?
Old Oct 20, 2004 | 03:10 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
yes they are, the 6 and 8 cylinder cars all used the same intake Y and air boxes. above when you were only referring to a TPI airbox, i wanted to make sure you used a camaro airbox and not a firebird intake setup. the intake ducting on a firebird sucks and they are restrictive so it woudl be wise to make sure you use the camaro setup. good luck.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
