Max HP on 305 TPI?
Old Oct 19, 2004 | 10:09 PM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
Max HP on 305 TPI?
ok guys i just got a white 91 Z28 camaro with a 305 TPI and was wondering what is the max horsepower this engine can produce?
Old Oct 19, 2004 | 11:08 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Re: Max HP on 305 TPI?
Go to this page and scroll down to find your vehicle. https://www.thirdgen.org/newdesign/tech/techdb.shtml
If you want more power you gonna have to pay.
Old Oct 20, 2004 | 12:05 AM
Car: 91 Z28
Transmission: 4l60e
so what is the best way/combo to gain horsepower on a 305 tpi?
and what do u think my engine is pushing out now with the mods in my sig?
Old Oct 20, 2004 | 12:40 AM
DON 88T/A's Avatar
Well you have a car that could run solid mid 14's or more as it sits,and with headers/gears/converter could be knocking on 13's ...if you do heads/cam and a good tune with traction a 12 sec et is possible..not alot of 12 sec 305TPI 's around but alot of that is people just end up going with a 350...
You can get a 305 built up strong (bottom end)then stick a blower or turbo on it,or N20,and run great times...
The big thing is,that people figure for the cost to make a 305 handle good power,you can get a 350 block,bore it over,stuff it with forged internals,and have more potential for close the same price....if your stuck on using a 305..yeah it can be made to handle alot of power,but you can get more potential by spending a little more on a 350+ motor...
Old Oct 20, 2004 | 01:12 AM
Car: 91 Z28
Transmission: 4l60e
oops forgot to mention in my sig that i already have 3.42 gears.
so if i got LT1 heads,hooker headers,converter,camshaft, and a 100 shot of nitrous would high 11's-low 12's be possible?
i want power but i dont want to sacrafice too much economy because right now im prob getting about 10-12 mpg and about 14-16 highway
Old Oct 20, 2004 | 01:51 AM
DON 88T/A's Avatar
Lt1 heads?/..Too much work ..L98 aluminum ported will support good power and won't need rigging like the Lt1's...
Headers is good /along with a stall (match with cam)and a 100 shot you should get your 12 sec et with traction...please remeber our cars are getting old...the rings/pistons ect..have been through alot...when you add power adders your living on borrowed time...yes newer LS1'S hold up to a little N20,but we'll see where there at in 12+ years...if your doing this on a stock bottom end 305 it won't last very long...
What is your budget...if you don't mind me asking?...
Old Oct 20, 2004 | 04:16 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
a 305 is no different than any other engine, the sky is the limit dude. Preston Smith has a 305 car running 9s in the quarter with a turbo. do a search or just hang around this site for a while you will see what it takes to make a 305 run, this topic has been covered millions of times. horsepower is a direct result of how much money you want to spend
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
