What 2 hoses connect to IAC housing?
Old Oct 23, 2004 | 08:53 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I am finishing up little detail stuff before I fire up my 69 327 TPI conversion. The IAC motor housing has one port pointing straight forward and one that comes out on the side. What did these connect to on a stock 3rd gen TPI? Can I just leave them open? This is in a 77 Camaro. I am using an 88-89 Trans Am intake ducting setup, flipped upside down so it is on the driver's side.
Old Oct 23, 2004 | 10:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I think you're talking about the TB coolant lines...you should be fine with out them....many do the "TB Coolant Bypass" mod.
Old Oct 23, 2004 | 11:19 PM
Car: 2000 BMW M5
Mike, are the two hose connections on this IAC for routing coolant through the throttle body, as you mentioned, or for something else? These are the two connections I'm trying to identify the function of.
Old Oct 24, 2004 | 12:09 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm pretty sure those are the coolant lines, I'd have to pop my hood to verify...but it's raining right now and I'm staying dry
Old Oct 24, 2004 | 12:38 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Those are the tb coolant lines. You can do a tb coolant bypass by simpling connecting the lines together. This keeps the tb colder, adding hp. Not earth shattering power, but some. It is one of the "free" mods you can do to a TPI motor. You can find out how to do it in the Tech section.
Old Oct 24, 2004 | 04:38 PM
Car: 2000 BMW M5
Thanks guys. Speed, I don't need to do a "conversion", my 327 tpi setup didn't have provisions for the throttle body coolant circuit to begin with.
Old Oct 24, 2004 | 06:58 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Re: What 2 hoses connect to IAC housing?
Anyone know if i could do the same thing with the air duct on my 86 t/a that im converting from Carb to tpi? or am i gonna have a problem with the duct hitting the upper radiator hose?
Old Oct 24, 2004 | 07:41 PM
Car: 2000 BMW M5
Vortec, you will be fine using the 88-89 style intake ducting flipped like I did. I am using a stock long neck TPI water inlet and the stock part # TPI upper radiator hose. It clears the intake duct with a lot of room to spare.
Old Oct 25, 2004 | 08:21 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Unless somebody plugged the coolant port on the front of the intake manifold already, then it did have it. But, there's no reason to use it. On my Camaro, I run the coolant from the port on the intake manifold directly to the heater core, then back to the radiator.
Old Oct 25, 2004 | 11:40 AM
vortec77's Avatar
Car: 86 T/A
Thanks 327
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
