should i run an AFPR?
Old Oct 26, 2004 | 03:46 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
going to be finishing up the engine install soon (i hope), and was thinking about if i should run an AFPR with a bigger cam and more lift? and what the "advantage" might be? (LT4 hotcam, going to .525 lift w/1.6 rockers) thanks...
KAM
Old Oct 27, 2004 | 07:30 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
An AFPR is always a very good tuning tool. With the right dialed in fuel pressure, you will maximize your RWHP. But, of course, this means that you also have a fuel pressure gauge. When the car/engine is all done and you've completed the minimum air procedure and reset the TPS and static timing, get on a chassis dyno and fine tune the fuel pressure that gives you 12.8 to 13.0 AFR while in PE mode AKA WOT.
As a starter, you can set the fuel pressure at 48psi. But if you run the car at WOT (before you get on the dyno) and hear audible knock, then increase the fuel pressure until the knock goes away.
I recommend the Holley AFPR.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
