Original Lt-1 Heads
Old Oct 27, 2004 | 02:45 PM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
Original Lt-1 Heads
Can original LT-1 heads that were used on 71 Camaros, with the 370HP 350 for example, be used on a TPI setup? I have found a set that are fully race ported and polished with double valve springs and erson roller rockers for about 400 bucks. And I'm pretty sure theyd be able to make some good power. Moreso, would these be compatible with a Stealthram Intake? If so, I could be lookin at gettin' one helluva good setup here.
Thanks for the help.
-Justin
Old Oct 28, 2004 | 08:40 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I'm running 60s 327 Fuelie vette heads with 2.02 intake, 1.7 exhaust valves on a newly-converted 1969 327 TPI. Any of the aftermarket TPI intakes, like the stealthram, will have dual pattern center bolt holes that fit either pre 86 or post 86 heads, so yes, it will bolt right up to your heads. Like in my case, your heads will be overkill for a stock TPI intake due to the fact that the heads keep flowing out to 6500-7000 rpms, and the intake quits at 5000. I did extensive porting and siamesed the stock TPI manifold base, and then ported the plenum, so I should be good to the 5500 range. My hydraulic cam peaks around 5500-6000, so I'm hoping the low end torque I'm gaining from the TPI will offset the small loss of top end I'll see. A stealth ram would be a good choice for you.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
cRoe4
Aug 7, 2015 08:46 PM
