Idle problem
Old Oct 27, 2004 | 05:02 PM
NCGiant's Avatar
Car: 1990 Iroc-z convertible
Engine: 305 TPI LB9
Transmission: 700 R4
Idle problem
When my engine is warm, if I come to a complete stop the idle drops every 5 seconds or so. It bounces right back and then does it again. At the same time the rpm's drop, the voltage drops in sync. It continues to do this until I accelerate, then it stops right away, and the voltage stays put just above 13. Any ideas fellas?
Old Oct 28, 2004 | 06:36 PM
rkoontz52's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: t-5
idle problems
try going to a shop that uses BG Products, and get an induction service, i did this on mine and it helped with the unsteady idle, i did mine for free though, working in a shop has its benefits
Old Oct 29, 2004 | 03:27 PM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Re: idle problems
Thats the stuff that has the colored plastic chips in the bottom of the can right? If so, that stuff works great!!
Old Oct 29, 2004 | 06:19 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
what is BG products? Im having problems with my idle & would like to trie that too.
Old Oct 29, 2004 | 08:48 PM
Morley's Avatar
Barry Grant
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
