like the title says i got the big three but still no starting. could it be the vats?? another idea is that because my faceplate isnt on mabey it has a built in security system? is that totally stupid?? please help i cant stand to see my poor bird just sitting. when i crank it wants to start but something is holding it back.
If you have fuel, air, and spark then your problem is not VATS related.
this might be a dumb question but if the chip in my key is messed up what will happen? will it crank forever or will nothing happen?
Quote:
Hey Rainman, I've got an 85 5.0 tpi that I just put an 87 ecm,harness in and I have the same problem. I got all used parts, ECM, chip etc., supposed to be all good but hours of TS and still same thing. Someone on this board told me to go to http://www.chevythunder.com and there you will find every thing you need to know about TPI. The troubleshooting flow charts I think helped me the most. I think I have a bad ECM, at least this one didn't cost anything, but I guess I'm paying for it now! Let you know how it goes in a day or two.Originally posted by Rainman
And thanks to who ever posted that link for me. Much help.
Doug
what does everyone think about the ignition module??? i tried to get it tested but it was too late. im really stumped on this one.
Like I said, check out the troubleshooting flow charts at http://www.chevythunder.com they are simple ways to diagnose problems w/o alot of confusion.Originally posted by Rainman
Doug
after pokeing around that sight for a little bit i found the trouble shooting charts i needed. thanks a lot man. ill have to put those to use tomorrow. thanks again for the link.
has the motor jumped time. what was you doing the last time it run. Did it just die or did you cut it off and it not start back. You have fuel but how much pressure. Try spraying some brake parts cleaner in the intake while you are turning it over.
