why does my timing change?
Old Nov 9, 2004 | 10:51 AM
BigBiscuit's Avatar
Car: 86 Iroc-Z28
I reset the timing on my 86 Iroc 305 TPI about two months ago and when I checked it this morning it had advanced way off the tab. This time I followed the directions and bypassed the computer (disconnected the brown wire with black stripe). What is the chance it will change again on me?
I will also mention that for a while I was getting a code 32 EGR malfunction...although it's been a couple weeks since I've had it. I know I shouldn't reset my timing with active trouble codes...could this code be affecting my timing?
Also, does anyone know a fast way of checking the condition of your EGR valve without removing the entire intake plenum?
Old Nov 9, 2004 | 11:45 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
If you set it last time w/o unhooking the ECM then it was way off this time b/c the computer changes the timing contantly based on RPM and load...
Old Nov 9, 2004 | 05:27 PM
BigBiscuit's Avatar
Car: 86 Iroc-Z28
Thanks. I learn most things the hard way.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Thirim
Aug 9, 2015 06:19 PM
