Spark knock coming off idle after WOT
Old Nov 10, 2004 | 10:38 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I recently got a problem of whenever I do a good WOT run, the next light or stop I make, when I take off I get some ping(about 1 full second and under 2k), but only after a WOT run. The harder the run, the more ping it is.
It started it recently. No tuning or changes were done when it started so I think it is a mechanical problem, although it does seem to do it when spark advance comes in.
I have changed the plugs and no help. FP is steady and timing will be confirmed tonight.
Oh yeah, car in sig(speed density)
Chris
Old Nov 10, 2004 | 10:57 AM
Morley's Avatar
Possibly an injector that is sluggish.
Old Nov 10, 2004 | 01:49 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
humm......no easy way to test that :-(
What is the best way to test injectors with out pulling them???
The car is rich
Chris
Old Nov 11, 2004 | 02:21 AM
Morley's Avatar
The car is rich
Chris
Injector balance test. That leaves the injectors in the engine, but you need the tester and a fuel pressure guage. Actron used to sell the tester for $20 from their site, don't know if they still do or not.
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
