does any one have a 400 TPI with MAF
Old Nov 10, 2004 | 10:44 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hey guys i am realy realy set on using a 400 but i am told it is kind of hard to do and use tpi... but i realy want to usemy tpi set up for now..... right now it is an 86 305 tpi tyhat i will be using.... so what will i have to change to use the tpi on a 400.... i have herd what is needed to be changed for a 350 but not a 400.
Old Nov 11, 2004 | 09:00 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
I ran a 415 with the stock TPI intake, I went to 24# injectors and reprogrammed the PROM, it ran great until about 4500 then it fell dead on its face.
Old Nov 11, 2004 | 10:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, I got a 395 cu.in. stroker in my MAF '87 IROCZ. Is that close enough? Details in my sig, and I do burn my own Eproms.
Mechanically, I dont know if there would be any mismatch between the heads and intake, such as, bolt holes not aligned.
Old Nov 11, 2004 | 11:06 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I have 389 CID motor running a MAF but it's a Granatelli adjustable MAF. I think you won't be happy with a stock intake and runners on a 400.
Old Nov 12, 2004 | 04:53 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
With 400 cubes, you should have plenty of bottom end grunt, therefore in place of a TPI (which is taylored for more bottom end) install a Holley Sleath Ram, and spec the cam accordingly. I have been considering doing the same thing next year.
Old Nov 12, 2004 | 04:59 PM
z28monster's Avatar
Car: 86 IROC-Z
i would be using slp runners, base, and a 58 mm throttle bodie... would that help me out a bit ata ll....
Old Nov 12, 2004 | 11:32 PM
89Warbird's Avatar
Engine: 389 CID TPI
Yes, those will help. You'll have great low end torque. I do agree that you would be happier with a Stealth Ram if emissions isn't a concern.
89GTAOz
May 16, 2020 09:31 AM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
