firing order
Old Nov 15, 2004 | 12:18 PM
jamesmidnight's Avatar
Car: 89 Formula 350
firing order
just did a tune up on my 89'formula 350 TPI, car will not start. I have external coil model of the TPI and not quite sure where each number cylinder matches up on this disributor. On regular HEI distributor I have no problem finding the order.I used a repair book for the firing order which i am sure is correct but, not sure if it is on the right spot. Any help is appreciated.
Old Nov 15, 2004 | 12:28 PM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
Get the #1 cylinder at TDC and take off the dist cap and the rotor button will be pointing at where the #1 spark plug wire should be. The firing order is 1-8-4-3-6-5-7-2. Good luck and I hope this helps.
Old Nov 16, 2004 | 10:03 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Someone has attached this pic when i had trouble with my firing order..
Old Nov 18, 2004 | 11:42 PM
C20T/A's Avatar
Car: C-20
Engine: 260 boat anchor Mexican 350 (crate) TPI (MAF)
Transmission: THM-400 I turn 3500 (which is where my pos engine's power starts droping off) at 80 I need a 4L80-E
good old reliable = 18436572
47 swap cam = 18736542
Gen3(ls1) style = 18726543
:lala: Dodge = 18436572:lala:
Ford = 265foundonroaddead43187
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
camarohelp
Sep 22, 2015 03:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
