Is there an aftermarket ECM that plugs into the stock harness?
Old Nov 16, 2004 | 10:15 PM
player 88's Avatar
Engine: 360 .060 over TPI
Is there an aftermarket ECM, i.e. Haltech, Elctromotive, Holley etc. that will pug into the stock harness connector?
thet woudl bethe easiest way to upgrade and tune, instead of using a "piggyback " or DYI PROMS.
thanks
Steve
Old Nov 17, 2004 | 12:43 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
I'm not sure if there are any or not.
But, why do you want to get rid of the current ECM? Both the 165 and 730 do a good job at managing the engine and can be modified to do pretty much whatever you want.
If you don't want the hastle of changing chips and so forth I'd suggest you hop over the DIY Prom page and search for Emmulators. With one of these you can tune on the fly without having to burn a bunch of chips.
Old Nov 17, 2004 | 06:55 AM
player 88's Avatar
VERY COOL!!!
The emulator would be EXactly what I would like!!
THANKS!
Old Nov 17, 2004 | 09:48 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
You can use a DFI 6.32 computer and a Dan White Racing interface harness. This is what most guys are using with a DFI. I have used this for the last 8 years and it has worked great. The complete install takes about an hour and is pretty much all plug in.
Do a google search for Dan White Racing. They have info on their web sight.
www.geocities.com/dzperf
Old Nov 17, 2004 | 09:52 AM
player 88's Avatar
what is a DFI 6.32 computer?
Old Nov 17, 2004 | 10:37 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Someone correct me if I'm wrong,
The DFI unit is from Accel, its a speed density stand alone ECM which you tune via your laptop.
Go onto Summit Racing site or Accel's for a good description.
Old Nov 17, 2004 | 10:54 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
The DFI was designed as a stand alone. Dan White developed an interface harness that ties the DFI computer into the factory harness and includes the plug for a laptop. The system is a Speed Density system. A harness is used that runs from the TPS to a MAP sensor. One wire needs to be run from the mass air plug to the TPS harness. Pretty much a straight forward installation.
midge54
Sep 2, 2020 07:13 PM
355tpipickup
Aug 19, 2015 10:02 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
