Who has a painless TPI harness (I do). Where is the "set timing" wire?
Old Nov 17, 2004 | 12:36 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have a MAF TPI setup on a 69 327 using the Painless MAF harness. If you have a Painless SD harness you will still be able to answer my question. Where is the wire you disconnect so you can set the baseline timing? I know the Painless harness relocates relays that are normally underhood in the passenger compartment, so I don't remember if this little plug in blade-style disconnect is in the pass compartment now or under the hood. If its under the hood, it must be somewhere close to where the wires come out of the firewall, no? I covered all my wiring with looms after my conversion install a few weeks ago, and now I have to access the disconnect so I can verify the timing.
I only need to know the location of this wire for a Painless harness, the factory location is likely different from what I have.
Thanks!
Old Nov 17, 2004 | 01:54 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Mine is about a foot from the ECM where the relay section comes off of the harness. It is the wire that is brown with a black tracer.
Attached is a picture of where it is on my harness. (Don't mind all of the other wiring)
Old Nov 17, 2004 | 07:05 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
327 , the brown wire with the black stripe in the center of it.
Old Nov 18, 2004 | 12:20 AM
Guest
Guest
Posts: n/a
Mine was same place, about a foot from the ecm. I cant remember if it came with the single in line weatherpack connector that is on there (I used a few of these myself for other purposes) but I'm thinking it did.
Old Nov 18, 2004 | 12:47 AM
Car: 2000 BMW M5
Thanks guys! Especially thanks to eric for the photo, this caused my "aha!" moment. I know where the disconnect is now. For some reason I was expecting a blade disconnect (like the cheezy "weather proof" ones I used on my 4 wire o2), not the huge GM weatherpak disconnect. I confused meself with all this newfangled wiring.
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
