305 Hsr
Old Nov 18, 2004 | 04:36 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
Transmission: Built 700R-4
305 Hsr
would the HSR work on a stock 305 out of an RS? i want to convert over to TPI , so i thought maybe ill just go all the way and do a HSR while im at it. let me know if anyone else has tried this and done it sucsessfully, cause im only a bagger at kroger! i dont have alot of $$$
Old Nov 18, 2004 | 04:42 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
well the swirl port heads your throttle body 305 has are a huge bottleneck. as are the stock exhaust manifolds and the stock cam. a HSR would prolly work OK on a healthy 305 with a cam and a real good set of heads. there is nothing wrong with TBI, i would just get a set of headers, a cam, and a better set of heads and keep your TBI. you could also upgrade to a better intake manifold and a better throttlebody. TBI motors can run real strong when correctly modified, be unique and keep your TBI setup there isnt a thing wrong with it.
Old Nov 19, 2004 | 02:57 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you don't have a lot of money to spend. Do not consider getting a HSR. You will have to put to much money in the engine and drivetrain to be happier. Almost everything would have to be changed to warrant that change, even then, it would not be too good of a street car.
Old Nov 19, 2004 | 04:47 PM
harpo_87's Avatar
Car: 91' Camaro RS
Engine: LO3 305
thankyou then would you recommend the TPI?
Old Nov 22, 2004 | 02:24 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
stick with TBI and change the intake, heads, cam, install headers, and go low 14s
Old Nov 22, 2004 | 11:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Go with TPI, purchase a wider aray of more parts that are more avalible and get more power and better gasmilage. It is opinion, and we have a difference. I love my Stealth ram though.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
