383 stroker
Old Nov 19, 2004 | 04:09 PM
acidcore86's Avatar
Car: 89 GTA, 09 G6, 03 E250
Engine: TPI 350...Soon to be a 383
Axle/Gears: Borg Warner
383 stroker
Hi guys.
Question: If I build a 383 out of my stock block(350 of course), and use the factory tpi and heads until I can afford better flowing components, will it cause damage to the short block?
Old Nov 19, 2004 | 06:10 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
No of coarse not .. But you do have to get some block clearance work done to clear the rods from the longer stroke crank..
Old Nov 19, 2004 | 06:25 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
watch the cam clearamce too if your using a big cam
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
