TPI/LT1 Air filter compatability
Old Nov 20, 2004 | 10:13 AM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
Do the TPI and LT1 throttle bodies have the same front opening? I want to use on of the 90 degree necks to reroute my air filter but they only list them for the LT1.
Sorry for the newbie question...
Old Nov 20, 2004 | 05:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Hope I understand your question correctly. I'm using the LT1 elbow on my setup even though I have a MAF. The oval side to the throttle body is exactly the same. However the side to the airfilter is 3 1/2 inches in diameter on the LT1. The TPI is 3 inches in diameter. I made up an adaptor to make up the difference. I hope this answers your question. Allen
Old Nov 21, 2004 | 12:13 PM
TPIJeep's Avatar
Thanks thats what I needed to know, I run a MAP sensor so the other end isn't a problem, glad to see its a bit larger!
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
