injector sizing?
Old Dec 15, 2004 | 05:04 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
injector sizing?
im putting my 305 tpi set up onto a mild 350 and i am going to buy new injectors and am wondering what size would be sufficient? i am also planning on running a 100-125 dry nitrous kit on the motor...
24's, 26's, ..30lb/hrs??
(i have a stock fuel pump and an adjustable regulator)
Old Dec 17, 2004 | 07:23 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Get 24#/hr Ford Racing (AKA SVO) injectors. Run the 350 ECM and adjust the AFPR for two cases: 1) when using NOX, and 2) when not using NOX. A chassis dyno is your best bet to determine the correct fuel pressure.
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
