anyone know how to build 396?
Old Dec 17, 2004 | 05:26 PM
l98+t5's Avatar
Car: 1988 camaro iroc-z z-28
Engine: L98 5.7 liter 350
Transmission: T-5 manual 5-speed
been thinking about what engine combo to stuff between the fenders and i ruled out a lot of things and am thinking about a 396. does anyone know what EXACTLY has to be done to a 350 to make it a 396 ? i dont want to go with a 383 because its to common now. but i like the sound of a 396. im looking for the bore size,rod length,crank stroke. also any block mods to fit.
Old Dec 17, 2004 | 06:07 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
Never heard of anybody making a small-block 396 before, doesn't mean it can't be done though. 396 from the factory was a big block chevy. Custom ground crank would get you the displacement - you'd need a 3.88 stroke with a .030" bore. Seems like extra hassle to me though. If you want to be different you could punch it out .060" with a 400 crank and make a 388. Just an idea.
Old Dec 17, 2004 | 06:10 PM
l98+t5's Avatar
yeah ive been talking to a guy and he says that .030 over with a 3.875 crank (not sure on rod size what did a stock 350 come with) and it would eaqual out to a 396 but a small block version. just somthing i havent herad muchh of so it would be new. not sure on valve to piston clearance though
Old Dec 17, 2004 | 06:18 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
yup, you'll need custom pistons, and you'll have to clearance the block too. There are companies that make cranks withthat stroke for a 400 block but not sure about 350, journals are different iirc.
Old Dec 17, 2004 | 07:32 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
If I were building one I would use a good 4 bolt 350 block .030 overbore, get a Scat 3.875 stroke shaft made for 6.00 rods, get a custom set of JE pistons made and taylor the piston to your head and desired compression ratio.
You may have to clearance the rods a bit for camshaft clearance and do I little milling on the bottom of the cylinders and pan rails. It really wouldn't be that bad of a job for a shop that was equipped with the right tooling.
Old Dec 17, 2004 | 08:48 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
A 350 block bored .030 over with a 3.875" stroke will come out to 395.x cubes. "People" like to call it a "396". GM High Tech mag biult such a motor called Magnum TPI. I built the same sized motor for my '87 IROCZ. I prefer not to confuse the SBC 395.x with the BBC 396, so I call my motor the correct cubes, a 395.
Edit: the rod length is 5.85", but that has nothing to do with the cubic displacement.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
