HSR help..
Old Dec 21, 2004 | 08:03 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
HSR help..
Ok my heads are in and my 350 block should be out of the shop tomorrow. Been a very great day!!
Well any-how I also bought HSR and looing at it I cant seem to figure out they the hole in the bottom of the plenum between the runners is for??
I have 4 vacuum places in the back and Holley shows them on the docs and where they want them hooked up.
THEY SAY NOTHING ABOUT THIS taped hole in the bottom center of the plenum.. What is this for
Oh yea my cam, lifters, rockers, springs, toque converter, EVERYTHING came in today.. It is like a PARTY!!!
Sorry just to happy.. I am still wondering what the taped hole is for.
Old Dec 21, 2004 | 08:08 PM
rawley2's Avatar
Ohh I also found the charger to my digital camera today so I can post a pic if that helps. Wow this really has been a great day!! :lala:
Old Dec 21, 2004 | 11:05 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the hole on the bottom of the intake plenum, in between both sets of runners is for you MAT (also called IAT) sensor.
Old Dec 22, 2004 | 06:42 AM
rawley2's Avatar
Old Dec 27, 2004 | 10:19 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Do not bother putting you IAT in that plenum, it is one big heat soak. By moving it into the air intake tube I saw a 20* temperature drop on an average summer day.
Old Dec 27, 2004 | 10:58 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
I use the hole in the bottom for the PCV valve hose. This way it evenly distributes the oil vapors to all cylinders, rather than the back two.
Old Dec 28, 2004 | 10:18 AM
Tibo's Avatar
Car: 1991 Z28 Vert
I was running the PCV from that location untill I had to change the intake gasket. When I pulled the HSR apart I saw how much oil was being sucked up into the plenum and then down the runners, it was a considerable amount. So I did some research and found that PCV only needs 2 or 3 inches of vacuum. I was running it at full vacuum.
Needless to say I do not have PCV at the moment. I think you might also find the like.
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
