Emissions on a 89 5.7
Old Dec 28, 2004 | 02:06 AM
Verviticas's Avatar
Engine: L98 5.7
Hey all, Long story short, Cant pass emissions.
Failing CO on idle. O2 sensor ect has all been checked and replaced. Niether i nor my mechanic and figure out what else todo. Cat is good and new.
There is oil burning at start up (thought to be worn valve steam seals?) will redone heads help me pass emissions?
Thanks.
Old Dec 28, 2004 | 04:32 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Emissions on a 89 5.7
Thanks.
Doing a valve job is good even if it did pass.
Change the oil, run it for at least a half-hour before the emissions test.
What's the state of tune i.e. spark plugs, rotor, wires ...etc.
If it still fails take it to another shop, my sister's 92' burb failed 4 times at one place even after replacing all the usual stuff, and past at another without doing anything to it.
Old Dec 28, 2004 | 04:44 AM
Verviticas's Avatar
Engine: L98 5.7
Plugs, wires, rotor all good and new.....
even played with timing to hell to see if i can cheat a bit. We have a smog machine to test what its reading right now cause it costs money every time to go to smog.
Ill try another place, maybe ill get lucky....
But my question is, does the burning oil negatively affect my CO emissions. If not does it effect any emissions at all?
Old Dec 28, 2004 | 05:19 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Here's a link that might help answer the questions.
Smog
Old Dec 29, 2004 | 10:03 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Don't know what I was thinking, no, the oil getting past the valves should not affect CO, but will increase the HC significantly.
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
