Valve adjustment?
Old Dec 30, 2004 | 03:30 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Valve adjustment?
I just dropped in a 383 roller motor into my Bird, and to make it run well, I had to adjust the lifters to almost zero lash. Is this not enough? I know on flat tappet, hydraulic lifters need to be turned down anywhere from 1/4 turn down to a full turn down. Are the rollers the same?
Old Dec 30, 2004 | 11:09 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Hydraulic lifters (including the factory hydraulic roller lifters) have the valve adjustment set at 1/4 turn past zero lash, at least for the hi-output motors. That is how I adjust my valves, I found this adjustment in several books I have on modifying TPI motors.
Old Dec 31, 2004 | 01:14 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
Check the cam card it should tell you the required valve lash.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
