Accel 58mm T-body
Old Jan 13, 2005 | 07:00 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Accel 58mm T-body
Has anyone made or adapted an airfoil to an Accel 58mm throttle body?
After looking at the inlet on the Holley, BBK etc., I can't help but think that an air flow improvement can be made.
www.geocities.com/dzperf
Old Jan 13, 2005 | 02:18 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
None are made for either the Holley or the BBK/Edelbrock throttle bodies that I am aware of.
They are already "smoothed" and in essence have one built in already (at least my Holley 52mm and BBK 58mm do, and so do the ones pictured on the web sites).
Old Jan 13, 2005 | 02:53 PM
KiLLJ0Y
Guest
Posts: n/a
its already built into it..
Old Jan 13, 2005 | 03:55 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Maybe I wasn't clear on my original post. The Accel or Lingenfelter throttle body has a blunt or flat face between the bores of the throttle blades.
The Holley, BBK/Edelbrock are made with with a smooth radius between the bores. I believe that the Accel throttle body suffers from turbulence at the inlet and that it can only be corrected by having a smooth radius.
Old Jan 13, 2005 | 04:54 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have read where people thought the casting was a little rough and smoothed out the throttle body. You could do the same. Allen
Old Jan 13, 2005 | 07:15 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I won't argue the necessity of an air foil on this setup. Here is a pic to facilitate the discussion.
The air inlet adapter is a large oval that attaches to the face of the TB (I can post pics if necessary).
-Schultzy
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
WejaZ28
Oct 3, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
IROCNParts
Sep 24, 2015 10:50 AM
