tpi combination, good choice?
Old Jan 14, 2005 | 05:14 PM
panther's Avatar
Car: 1987 Iroc
Engine: 5.7
I am about to place an order for the top end and exhaust of a mild L98 to replace my current L98. Here is what I plan to order;
AFR 180 heads
ZZ4 cam
Scorpion 1.5RR
Comp Cams Hardened Rods
Heddman 1-5/8" LT's
Flowmaster American Thunder exhaust
Currently, the short block has been fully machined, decked and bored (.030") with KB flat tops that will give me 10.1 compression with 64cc and 9.7 with 68cc (AFR 180).
I have posted this here because I FULLY intend to keep the MAF TPI system. I thought long and hard about it and I want the engine bay to look stock minus the emissions stuff. I would like to know if anyone with similar combinations would change anything from their experience. Also, if you do have a setup close to this, do you have any type of performance numbers? I'm hoping I will produce a decent amount of low end torque by keeping the TPI.
Old Jan 14, 2005 | 07:29 PM
91 z28 350's Avatar
Car: 91 Z28
im thinking about doing the same combo just diffrent cam but i also want to get a edelbrock intake manifold and some aftermarket intake runners (not sure which ones yet)
Caspar
Jun 19, 2016 11:19 PM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
squiggy2
Aug 9, 2015 09:30 PM
