replacing vacuum hoses, will these do?
Old Jan 16, 2005 | 06:54 PM
sting's Avatar
Car: '87 TransAM
Axle/Gears: 10 bolt 3.23
Here is what I'm looking at, blue hose kit: http://store.summitracing.com/partde...=blue+hose+kit
The kit features 10 ft. of 3 mm hose, 5 ft. of 6 mm hose, and 2 ft. of 10 mm hose. In most cases, thats enough hose to complete most fuel injected cars.
Will that work? I'm looking to replace as many vacuum hoses as posible in one shot, everytime I go to work on something and disconnect a hose they crack and I have to run out and get more, plus blue would look decent. I know one vaccum line that has a checkvalve that goes all the way over to the other side of the car to the cruise control, thats why I'm concered if this is enough hose in their kit.
Also, I've searched posts for a vacuum line diagram, but i've only found that one small handwritten one of of chevythunder, is there a higher resolution/more clear one floating around? 89 TA 305 TPI
thanks for any help
Rob
Old Jan 17, 2005 | 07:40 PM
Vader's Avatar
You can get the silicone if you like, or just use factory EPDM hose. You may need a fairly long section for some of the runs:
Old Jan 18, 2005 | 07:16 AM
sting's Avatar
Car: '87 TransAM
thanks for the diagram, so that's not enough hose? How many ft of each should I be buying?
Old Jan 19, 2005 | 10:18 PM
Vader's Avatar
It's fairly cheap and easy to use a piece of string as a guage to measure the lengths of all the hose you'll want to replace. The pieces going to the cruise servo, vacuum canister, and EVAP control valve can be rather long.
You might want to consider inspecting/replacing the large hose to the power brake booster, PCV valve, and possibly the fuel vapor hose at he EVAP canister, so that you can be confident about all your vacuum hoses at once.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
