upgrading 305TPI to 350TPI need help
Old Jan 17, 2005 | 12:36 AM
bc5007's Avatar
Car: camaro
Engine: 305ci LB9
will this motor http://www.gmpartsdepot.com/store/pr...&Category_ID=2
fit into my 1986 iroc-z LB9 305ci? without any major adjustments? does that come with a computer?
Old Jan 17, 2005 | 08:44 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
You would need a 350 knock sensor, 22 lb injectors and a 350 memcal. I would look for another option for a long block though, the heads and cam in/on that one leave much to be desired. I believe they offer a L98 short block which would be better, you could also get a set of 083 knock off heads from pro topline for pretty cheap money.
Old Jan 17, 2005 | 11:11 AM
blackroc68's Avatar
I dont want to correct anyone,But he can use his original knock sensor. He should have a new prom burned for optimum performance. This is a mass airflow system!! same Knock sensor.
Old Jan 17, 2005 | 04:34 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I am somewhat amazed they get 290HP out of that motor.
The camshaft has .450" intake and .460" exhaust lift with hydraulic flat tappets.
The cast iron cylinder heads have 1.94" intake and 1.50" exhaust valves wit 76 cc combustion chamber.
Low lift. Non-roller. 76cc heads.
Old Jan 17, 2005 | 06:02 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
I did not know that...
Old Jan 17, 2005 | 06:05 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Could be right, in which case I stand corrected. I do know the speed density systems in 91 used different knock sensors for the two. Sorry if I messed you up and you bought an extra knock sensor!
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
