still to no avail just stalls
Old Jan 17, 2005 | 03:25 PM
1988 Massz's Avatar
Car: Acura now/Z in the summer
Engine: 5.7 tpi
Well my 1988 z 5.7l tpi with which I have redone twice aii the upper intake gaskets and replaced all the sensors again. The car will idle to an extent now and just stall. Well the significant popping noise in now enhanced by a whistling. Well I have started it and the car will smooth right out when opening up the throttle and then comes back down to idle anf falls flat fust eventually stalls. I believe I have a major vaccum leak somewhere but I cannot find it. Rechecked all the plugs and all ignition components are new. I have one other alternative to replace the original throttle body back on the car. I do not know any advive thanx Tim
Old Jan 17, 2005 | 03:31 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Did you hook up the small vacuum line on the bottom of the throttle body that goes to the fuel pressure regulator? That one's easy to miss/forget. Also, does the heater control valve have the vacuum line connected to it? Power Brakes connection? PCV valve? Hose between the passenger's side valve cover and the TB? EGR valve vacuum line to EGR solenoid? Plenum to EGR solenoid?
That's all I can think of right off hand....
Old Jan 17, 2005 | 03:56 PM
91Z28-350's Avatar
Options:
1) Use a rubber hose as a stethescope to narrow down the whistle location.
2) Use a propane torch, unlit, just venting the gas. Wave it slowly around the upper intake (TB, plenum, intake manifold), and when the idle fluctuates, go back over to narrow down the spot. Turn off the gas, look around and you'll see what you missed.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Jlanz55
Sep 29, 2015 08:55 AM
