sd baseplate question
Old Jan 16, 2005 | 10:32 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
On the baseplate there is a hole with 2 bolt holes to hold a plate on. Thru research I found this is for an egr valve. I need to find a gasket for it. What year camaro or corvette used this egr valve here so I can pick up a gasket??? Thanks in advance.
Old Jan 17, 2005 | 09:32 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
91's used the EGR valve for sure. You can also just cut one out of some gasket material available at your local parts store.
Personally, I'd keep the EGR valve. Actually helps more than it hurts....
Old Jan 17, 2005 | 03:57 PM
maroguy1's Avatar
Well everything for it has been deleted. The chip also deleted it. I got the engine compartment in pieces minus the short block. That will help though no one at the part store knew anything about it. THanks
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Dialed_In
Aug 20, 2015 01:45 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
