surging idle only in gear
Old Jan 17, 2005 | 06:02 PM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
My car is an 89 Trans Am 350 TPI. When idling in drive, the idle surges back and forth between about 600 and 1000 rpm. In neutral and in park, the car idles smoothly with no surging at all. It only happens when the car is in gear. What's causing this? Any help would be greatly appreciated.
Chris
Old Jan 17, 2005 | 07:29 PM
TPI-454's Avatar
Car: 1989 Trans-Am
Engine: 454-Motown SBC w/HSR
Transmission: 6-Speed
Re: surging idle only in gear
If its only happening under a load, then it might very well be a vacuum leak. However, stock MAF systems can be very tempermental. Even with no codes being thrown, I'd still make sure that all my connections are good (no pulled wires), and are each (each wire) giving adequate 'juice'...
Old Jan 18, 2005 | 02:25 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
check the resistence at the injectors, when in gear the idle is lower, so you can tell that it is surging, but when its idleing its a little bit higher rpm, it is probably still surging, you probably just cant tell. happened to me, changed injectors, works fine now
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
jbd1969
Aug 17, 2015 07:06 PM
